TwinTurbo.NET: Nissan 300ZX forum - The connectors are connected correctly
scooter4zx
on January 16, 2011 at 9:39 AM
Check for swapped connectors
posted by DE944
on January 16, 2011 at 12:12 AM
I had continuity between ecu harness and knock sensor plug.I guess my next step is the resistor trick.I just don't understand why the knock sensor would have gone bad from sitting.
code 34 det. sensor problem
scooter4zx
18:03:50 01/15/11
Re: code 34 det. sensor problem (n/m)
njz
19:54:08 01/15/11
Recheck your work, (n/m)
njz
19:57:32 01/15/11
DE944
00:12:32 01/16/11
The connectors are connected correctly -
scooter4zx
09:39:06 01/16/11
Just in case you need a new one.
jschrauwen
09:56:41 01/16/11
thanks (n/m)
scooter4zx
10:38:18 01/16/11
now i'm completly confused.
scooter4zx
12:19:27 01/16/11
Could something else throw a 34 code? (n/m)
scooter4zx
13:04:55 01/16/11
I know you said it already, but you're SURE of the connector
CoHPhasor
14:07:24 01/16/11
the vtc connector has a white sheath on it with black and
scooter4zx
14:56:51 01/16/11
I just cleared the ecu again and reversed the vtc and
scooter4zx
15:27:19 01/16/11
allittle change here
scooter4zx
18:34:16 01/16/11
Are your stock boost solenoids discod since you have a BC? (n/m)
Woody75 (Denver)
09:33:36 01/17/11
disconnected and removed. (n/m)
scooter4zx
17:24:02 01/17/11
Then safety boost is no longer an option. (n/m)
Woody75 (Denver)
19:43:53 01/17/11
woody how is it possible i'm throwing 34 with the resistor
scooter4zx
23:07:40 01/17/11
Re: woody how is it possible i'm throwing 34 with the resistor
DoomDay300
23:58:36 01/17/11
thanks for the input doomday but thats where i had it wired
scooter4zx
16:33:52 01/18/11
Re: thanks for the input doomday but thats where i had it wired
DoomDay300
17:19:39 01/18/11
I tried 3 seperate resistors (2 1mega ohm resistors 1/2
scooter4zx
18:41:46 01/18/11
Re: I tried 3 seperate resistors (2 1mega ohm resistors 1/2
DoomDay300
23:47:51 01/18/11
Just changed both 02 sensors to narrow things down and no
scooter4zx
16:30:10 01/20/11
Re
DoomDay300
01:19:24 01/21/11
